Take incredible low-light wefies with the ZenFone 4 Selfie Pro
SHARE:
The ZenFone 4 Selfie Pro is the perfect phone for those that want to look their best. Thanks to a DuoPixel camera system on the front and a Softlight LED flash, your selfies will look phenomenal, even in low light.
Let’s take a closer look at the front Softlight flash. Unlike many LEDs, which emit harsh light when they flash to fill an area as long and far as possible, the Softlight flash diffuses light. This makes it less harsh and casts fewer shadows or reflections, while still providing even illumination at short range.
ZenFone 4 Selfie Pro in low light
Even without the flash, the ZenFone 4 Selfie Pro has exceptional light sensitivity. A big f/1.8 aperture lets in plenty of light when you first take the picture, while large 1.4 μm pixels on the Sony IMX362 sensor capture more detail with less noise. That information is piped into the SuperPixel Engine, which is a dedicated hardware digital signal processor that intelligently controls ISO levels while keeping noise to a minimum. All of that results in twice the light sensitivity of a standard smartphone camera. The secondary front-facing camera has a wide angle lens, perfect for group selfies (or wefies). With a 120° field of view, the wide angle camera can capture more friends and more incredible backdrops in your photos.
ZenFone 4 Selfie Pro in low lightOn the software side, HDR mode helps to appropriately light up photos in challenging situations. Sometimes areas of a photo might be dark, such as subjects in the foreground, and other areas may be quite bright, such as lights in the background. The ZenFone 4 Selfie Pro takes photos at multiple exposures and combines them so that everything is equally exposed – nothing too bright, or too dark, so you can preserve all the details in every lighting situation.
Combining the front-facing flash, wide-angle camera, and razor-sharp 4K video capabilities, the ZenFone 4 Selfie Pro is great for capturing memories at night with all of your friends. Be sure to learn more about the ZenFone 4 Selfie Pro here.
