Top 10 reasons the ZenFone AR is the next big thing
SHARE:
The ASUS ZenFone AR is built from the ground up for augmented reality. There’s a lot to love about this cutting-edge smartphone, but let’s run down the biggest reasons why you should consider picking one up.
1. Tango augmented reality
Tango is the augmented reality system by Google which marries depth-sensing and motion-tracking camera technology. With the right apps, virtual objects can inhabit the space around you in fun, informative, and creative ways. For example, you could size up furniture for your living room, or chase monsters through your kitchen. It’s a brand new world of possibilities with augmented reality and Tango.
2. Daydream virtual reality
The ZenFone AR is the first Android phone to include both Tango and Daydream support in the same device. With the Daydream View headset, you can enjoy your own personal cinema filling your whole field of view, or dive into immersive games with the help of the included controller. The growing library of Daydream apps means you’ll always have new experiences right around the corner.
3. Incredible processing power
Thanks to the custom-tailored Qualcomm Snapdragon 821 processor, the ZenFone AR is able to construct vibrant 3D worlds on the fly. This requires not only an impressive amount of sheer processing power power, but energy efficiency, too. We are working with a smartphone, after all, which needs to be able to carry on with usual functions the rest of the day.
4. Next-generation camera
While the TriCam system combines every technology required for fluid virtual reality and augmented reality, the primary 23 megapixel camera can take some incredible shots. It has a large f/2.0 aperture, perfect for shooting in low-light. It can capture video in razor-sharp 4K, complete with optical and electronic image stabilization.
5. Premium construction
The ZenFone AR pushes boundaries, and it feels built for the task. With a burnished leather rear and precision-milled metal frame, you’ll enjoy a true feeling of luxury every time you take the ZenFone AR out of your pocket. During day-to-day use, the Gorilla Glass 4 cover will amply protect the screen. Overall, the fine craftsmanship at play will ensure this phone ages gracefully.
6. Mind-blowing sound
The finely tuned SonicMaster 3.0 engine produces premium audio in any circumstance. A new 5-magnet speaker design can churn out music louder than ever without distorting or damaging the hardware. Advanced signal processing by way of the NXP Smart AMP can handle audio at up to four times CD quality. Whether you’re in VR, or just relaxing with some tunes, the ZenFone AR will not disappoint.
7. A beautiful display
When using the ZenFone AR with the Daydream View headset, the screen will be quite close to your eyes. ASUS has made this display exceptionally sharp to maximize immersion. At 5.7 inches, your full field of view will be taken over. The Super AMOLED 2560 x 1440 WQHD screen will produce details at the sharpest definition and with the deepest colors.
8. Most RAM ever in a smartphone
The ZenFone AR manages to pack in 8 GB of RAM. You can read more about how RAM works and why it’s important here, but the bottom line is that having 8 GB of it in the ZenFone AR ensures it will be able to handle intensive processing tasks of any kind, not just those that have to do with augmented reality and virtual reality.
9. Advanced vapor cooling system
When operating at its peak, the Qualcomm Snapdragon 821 processor will generate a fair bit of heat. Luckily the ZenFone AR incorporates an advanced vapor cooling system to keep everything running smoothly. This heat pipe guides temperature away from the CPU efficiently without adding significant bulk to the device.
10. Lightning-fast autofocus
ASUS has been carefully refining its autofocus system over the course of several generations. TriTech consists of three mechanisms working seamlessly with one another. First, there’s traditional object-tracking focus. Then, there’s laser autofocus, which can detect the distance of subjects out to 1.5 meters, even in low light. Finally, phase detection autofocus is specialized at capturing subjects in motion. All of that comes together for a lock in under 0.03 seconds.
The ZenFone AR is an absolute feat of engineering. Dig into more details on the ZenFone AR product page.
