Meet the ZenFone 4 Max series
SHARE:
The ASUS ZenFone 4 Max is ready to help you go further with a wide angle camera and exceptional battery life. Thanks to ASUS PowerMaster technology, you can charge quickly, and enjoy a longer battery lifespan thanks to a series of safety checks.
Battery
The ZenFone 4 Max series packs a huge 5,000 mAh battery. It’s able to get you through two days of usage without a problem. The capacity is so generous that the ZenFone 4 Max series comes with a USB on-the-go adapter so you can use it as a power bank for other phones. It takes more than just a big capacity to keep it going for the long haul. PowerMaster technology manages battery usage meticulously.
ZenFone 4 Max battery
For one, it can dynamically adjust system settings when power levels get low. This includes lowering screen brightness, turning off antennae when the device is locked, and clearing out unused background apps. In the background, PowerMaster quietly runs 12 different kinds of checks whenever you charge up the ZenFone 4 Max and ZenFone 4 Max Pro. This includes voltage protection and monitoring temperature tolerances. Thanks to this level of care, the battery has a lifespan twice as long as competing brands.
Don’t worry if you don’t have long to charge; with only a 10% charge, the ZenFone 4 Max can last an incredible 91 hours on standby thanks to Super Saving Mode.
Camera
The ZenFone 4 Max series has a dual lens system to help you capture special moments no matter where in the world life takes you. The primary camera excels in taking photos in low light, thanks in no small part to the LED flash, large 1.12 µm sensor pixels, and an f/2.0 aperture. The second camera has a 120° wide angle view. This is perfect for capturing majestic landscapes, large group photos, big cityscapes, and lots more.
As for video, electronic image stabilization will come in handy when you’re shooting adventurous clips while on the move. Meanwhile, phase detection can lock onto subjects in motion in a mere 0.03 seconds. If you’re looking for some extra sharpness in your photos, the ZenFone 4 Max Pro bumps up both front and rear cameras to 16 megapixels.
ZenFone 4 Max camera
The front-facing camera is perfect for selfies thanks to a built-in beautification mode. Slim cheeks and lighten skin just the way you like it when taking stills, shooting video, or even broadcasting live on your favorite social networks. The front camera also enjoys a soft LED flash, so you can still look clear when shooting at night or in low-light.
Design
ZenFone 4 Max design
Contoured 2.5D glass provides both protection and unification of the front face. The premium unibody construction adds an additional feeling of confidence in day-to-day use. Sunlight Gold, Rose Gold, and Deepsea Black color options are bound to fit into your style.
Peformance
The ZenFone 4 Max series is powered by an octa-core Qualcomm Snapdragon processor. This helps manage multiple apps running concurrently, intense 3D gaming, and fluid responsiveness when navigating menus.
ZenFone 4 Max taking pictures
A triple tray keeps you connected in a number of ways. It has room for two SIM cards at once, so you never skip a beat between networks. These are compatible with 3G and 4G VoLTE networks in dual standby. The same tray also has a spot for a microSD memory card, which can hold your music, photos, and files without impacting internal storage. To top it all off, a fingerprint sensor can unlock the ZenFone 4 Max easily and securely in only 0.3 seconds.
The ASUS ZenFone 4 Max is an incredible companion for your daily travels. The massive battery and wide angle camera will help you go further in every way. Visit the ZenFone 4 Max product page for more information.
ASUS ZenFone 4 Max specifications
Display 5.5 inches
1280 x 720 IPS
400 nits of brightness
Processor Qualcomm Snapdragon 425 with Adreno 308 GPU
Qualcomm Snapdragon 430  with Adreno 505 GPU
Memory Up to 4 GB LPDDR3
Storage Up to 64 GB
MicroSD (up to 256 GB)
Rear cameras Primary: 13 MP, f/2.0, 1.12 μm sensor pixels
Secondary: 120° wide angleLED flash, electronic image stabilization, phase detection autofocus
Front camera 8 MP, f/2.2
1.12 μm sensor pixelsSoftlight LED flash
Audio Mono speaker with PMIC internal amplifier
Dual microphones with noise cancellation
Wireless 802.11 b/g/n 2.4 GHz; Wi-Fi Direct
Bluetooth 4.1
Dual SIM, Cat. 4 LTE with 150 Mbps down and 50 Mbps up
Sensors Accelerator, e-compass, gyroscope, proximity sensor, ambient light sensor, fingerprint sensor
Battery and power 5,000 mAh lithium-ion
MicroUSB 2.0
Software Android 7.1.1 Nougat with ASUS ZenUI 3.0
Colors Sunlight Gold, Rose Pink, and Deepsea Black
ASUS ZenFone 4 Max Pro specifications
Display 5.5 inches
1280 x 720 IPS
400 nits brightness
Processor Qualcomm Snapdragon 430 with Adreno 505 GPU
Memory Up to 3 GB LPDDR3
Storage Up to 32 GB
Rear cameras Primary: 16 MP, f/2.0, 1.12 μm sensor pixels
Front camera 16 MP, f/2.2, 1.12 μm sensor pixels
Softlight LED flash
Bluetooth 4.1
MicroUSB 2.0
Software Android 7.1.1 Nougat with ASUS ZenUI 4
Related Posts
Popular posts
Go To Top
