What the media is saying about the ZenFone 4 Max
SHARE:
The ZenFone 4 Max has made a big splash with the press. Let’s take a look at some of the early reviews from the most trusted media out there.
GadgetMatch
ZenFone 4 Max review from GadgetMatch“The 5.5-inch ZenFone 3 Max was a solid phone in itself; its successor does everything better and more. This is the phone you’d want for a long weekend up in the mountains with no electric socket to plug into. Not only will the battery endurance keep you happy till you get home, you’ll also have perfect framing for landscape shots using the wide-angle lens of the rear cameras.”
Android Authority
“Don’t let its specs fool you: while the device comes with features that you might expect from a high-end smartphone like a dual-camera set-up and a massive battery, the official starting price in Russia is RUB 13,900, or approximately $235 in USD.”
YugaTech
“The ZenFone 4 Max, is a mix of the old and the new. It has the old Snapdragon 430 CPU, 3GB RAM, 32GB storage, and HD display found in its predecessors, but with a new and more attractive design, dual rear cameras, and larger 5,000mAh battery. The ZenFone 4 Max is designed for users who are looking for a device with features found in more expensive devices but can withstand heavy usage and doesn’t break the bank.”
ManilaShaker
“If battery life is truly what you’re after in a phone, then the Zenfone 4 Max is what you can get. It has enough juice to dampen your fear of running out of battery life (and provide power to other phones), and with the lowest price out of all the Zenfone 4 units, the Zenfone 4 Max makes an interesting choice.”
TechRadar
“The obvious stand-out in the spec sheet is its 5,000mAh battery, which considering its thin frame is a marvel of engineering. This huge battery powers the efficient Snapdragon 430 with 3GB of RAM.”
The Droid Review
“With a support for fast charging, the handset is seen being used as a power bank as well – a standard feature across all Max handsets from Asus.”
Unbox
ZenFone 4 Max
“To keep their edge, ASUS has vastly improved the functionality and features of their ZenFone 4 Max to stay competitive with the offerings of their rivals. The ZenFone 4 Max isn’t just a one-trick pony anymore – it’s a great budget smartphone that offers a lot more than just a big battery.”
Trusted Reviews
“The only phone I’ve known in recent memory to offer real stamina was the wonderfully affordable Lenovo P2, which has now sadly been discontinued, leaving a huge gap in the market. Fortunately Asus has come rushing in to fill the gap with the Zenfone 4 Max.”
TechNave
“As for the dual-camera setup, it will comprise of a dual 13MP sensor with a 120° field of view. Clearly outclassing most mid-range phones by a mile. There’s also the 8MP front camera which is featured to be able to take 140° selfie panoramas.”
Those are some of the early impressions of the ZenFone 4 Max among the media. Be sure to visit the ZenFone 4 Max product page for more information.
